The web interface of my newly revived Z-Net (replaced microSD card) shows:
The interface as displayed in the Homeseer Controller management shows with a name of Z-NET and the interface says Z-Netv3. It seems like everything is working so I'm wondering about the Note from the Z-Net web interface. Does the name really matter? I assume it is working because of the reserved IP address.
I do have a secondary controller (USB Z-stick), but since things weren't working until I put the Z-Net back in place I assume it is functional.
Should I make the name match? I'm guessing I might need to disable the interface in HS3 in order to rename it as it seems greyed out.
Device Name | Z-NETv2 |
_ | Note: Be sure to update your HS3 Z-Wave plug-in settings if Device Name is changed. |
