Hi
I am having a lot of issues with a specifiuc Z-net that is outside the house in a secondary house on the same network as the main property that does not reconnect when there are small power failures. My HS4 is running on a battery power pack and have about 1 hour of juice, if the current only flicker, the secondary Z-NET never recovers.
the only way to recover is to stop Z-WAVE controler, reboot the Z-net and restart the z-wave controler.
As i am not always home when failure happens, i sometime loose the connection for hours.
Does anyone would have an idea for a script that i could run from an event in hs4 where i would stop the z-wave plugin, remotly reboot the z-net and then restart HS$ ?
I ave been told so many times that HS should recover from this kind of connection lost but it never never work.
thanks for any help
thanks for any help
