Sorry if this has been asked and answered. I searched but didn't find anything.
I'm running HS3 Pro on a low-power, fanless PC. Along with HS3 PRO the machine runs my weather station software. Nothing else runs on it and the setup has been running great for several years.
The PC has 4 USB-2 ports, 1 USB-3 port and 1 Ethernet port. The PC to network communication is over WiFi so the Ethernet port is not being used.
My Z-Net interface is plugged directly into the router, which assigns all the LAN IP's via DHCP. I have assigned static IP's to several devices including the PC and the Z-Net interface.
I recently plugged the PC into a UPS but I need the Znet interface on the UPS as well. It's located in a different part of the house right now.
My question is, can the Znet interface be plugged directly into the PC, either via USB or the unused Ethernet port?
Thanks.
Thanks.
System Information | |
Current Date/Time: | 1/2/2021 11:28:45 AM Central Standard Time |
HomeSeer Version: | HS3 Pro Edition 3.0.0.548 (Windows) |
HomeSeer: | Is Registered |
Operating System: | Microsoft Windows 10 Pro - Work Station |
OS Version: | 10.0.19041 Service Pack: 0.0 |
System Uptime: | 0 Days 16 Hours 6 Minutes 5 Seconds |
User Name and Access Level: | default (Admin) |
LAN IP Address: | 192.168.1.10 (HS3Machine) |
Client IP Address: | 192.168.1.10 (HS3Machine) |
Network Adapter: | Adapter -> Broadcom 802.11n Network Adapter IP: 192.168.1.10/24 MAC: 00:8E:F2:6D:61:C8 |
Network Adapter: | HomeSeer Adapter -> Loopback Address (localhost) IP: 127.0.0.1 |
Web Server Port: | 80 |
Number of Devices: | 308 |
Number of Events: | 155 |
Event Last Ran: | Climate : A/C Filter Run Timer STOP, Ran at 1/2/2021 11:10:17 AM |
Number of unique event scripts used: | 0 |
Plug-Ins Enabled: | BLShutdown:,BLOccupied:,BLBackup:,UltraLog3:,Pushover 3P:,BLLock:,PHLocation2:,HSBuddy:,BLStat:,Z-Wave: |
Processor Type and Speed: | Intel64 Family 6 Model 55 Stepping 8 at 1.86 GHz |
Modules/Threads: | 139 Modules, 94 Threads |
Available Threads: | 400 |
System Processes/Load: | 185 Processes, 4% Load |
Free / Total Physical Memory: | 4.01 GBytes / 7.88 GBytes (51% free) |
Free / Total Virtual Memory: | 4.65 GBytes / 9.13 GBytes (51% free) |
HomeSeer Memory Used: | 101 Mbytes |
Plug-In Memory Used: | 10 EXE Plug-Ins using 306 Mbytes |
