Move Devices between Z-Net Controllers
    What's the best way to move a Z-Wave device from one Z-Net controller to another without having to delete and recreating the device within HomeSeer?
    Ultrajones
    I think you will have to delete and recreate the device.
      Ultrajones
      I may not be understanding what you want to do, but on the z-wave tab of the device, there is a pull-down menu to set the controller ("Remote Interface to Use"):
      I change the interface to use quite often on devices by this method. In my case I have a main Z-Net and a few others spread around my house.
      "Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
      "Reboot and rejoice!" F. Pishotta, 1989
        Ultrajones
        Are you wanting to create a second Z-Wave network separate from your existing network?
          I think it depends on how your znet's are set up.
          If they are on separate / unique home IDs, then delete and add is your only option.
          If same home ID, then you can just move to a separate znet as stated by Richel.
          Each setup has their own pro's and cons.
          Len
          HomeSeer Version: HS3 Pro Edition 3.0.0.435
          Linux version: Linux homeseer Ubuntu 16.04 x86_64
          Number of Devices: 633
          Number of Events: 773
          Enabled Plug-Ins
          2.0.54.0: BLBackup
          2.0.40.0: BLLAN
          3.0.0.48: EasyTrigger
          30.0.0.36: RFXCOM
          3.0.6.2: SDJ-Health
          3.0.0.87: weatherXML
          3.0.1.190: Z-Wave
