Z-net starting to hang once per day
    #16
    Originally posted by rmasonjr View Post
    I'm not sure about that error. In BalenaEtcher and try turning off Trim ext{234} partitions and see if that helps.
    Hmm..... I'm using BalenaEtcher on MacOS, I don't see any place to set options such as Trim, Google doesn't turn any immediate matches up for MacOS. Any idea where I should be looking? (I haven't gone spelunking through the filesystem yet....).....
      #17
      My BalenaEtcher as a little gear icon in the top right for settings:
      I'm running 1.5.50 and I dont know if that is the latest version or not...
      79 Z-Wave Nodes, 131 Events, 383 Devices
      Z-Wave, UPB, WiFi
      Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
        #18
        Indeed mine does have the gearbox, but when I opened it up all it gave me was "Anonymously report errors" and "Auto Updates Enabled".
        regards,
        Paul
          #19
          It must be different for the MAC version:
          Z-Wave, UPB, WiFi
            #20
            Don't upgrade! ... I have version 1.5.116 on Windows and I see the same as paul reports.
              #21
              Heh. No worries. I'm gonna see if there are other approaches / software to use to write the image and give it a try
                #22
                If you're not afraid of the Linux command line ... this works great to mirror the running drive to another card mounted in a USB adapter.
                https://github.com/billw2/rpi-clone
                  #23
                  Yeah that's no problem. I'll go take a look at it.
                    #24
                    So interestingly - while I haven't successfully replaced the SD card yet, I also haven't had the box hang since I swapped the power supply for the POE Splitter. I'll keep tabs on it to see if flaky power really was the issue.....
