One of my Znets keeps restarting every 30 minutes, my other two are fine. The error I get in the log is: Exception transmitting to IP 192.168.1.XX (XX changed from IP address) : Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. Any ideas?
Znet Keeps Restarting Every 30 Minutes
First thing I would look at it whether the Z-Net device is rebooting. Best way to monitor this is to connect up an HDMI monitor to the unit. You can also ssh in; however all you'd see when it reboots is that the ssh session terminates.
If it is rebooting, check for a failing power supply. Substitute a different one and see if that changes the behavior.
If it's not rebooting, look for communication issues. A wireless connection is more prone to these.
