Just wanted to see if anyone else has tried a new z-net-g3. I ordered one to try out and use to replace one of my older first or second gen z-nets. I have 3 separate z-wave networks with the devices split out roughly by location. The new z-net showed up last Monday and I backed everything up and then installed the new one in the same location as one it would be replacing. The process went fine it seemed, but I went into zseer to see how things looked it almost everything was not reachable. At first I didn't try to optimize anything just let the system run and while I could control most things I started getting loads of these messages:
Failed sending Z-Wave command to device..
Some of the devices were some of the furthest devices from the controller, but others were some of the closest devices. I will say I've been using Z-wave for quite sometime and many of my devices are first gen so I'm not sure if that is an issue or not. I then looked deeper into the new controller and noticed there didn't seem to be any routing going on and the option to see/modify the route wasn't available via the z-wave plug-in. I left the system for hours to see if things would get any better on their own, but when they didn't I then tried to optimize a few devices. Many it would say it could not reach and others it would optimize one time then the next time it would fail. I rebooted devices and the z-net/plugin multiple times and at one point I had an optimize completely finish and it looked like everything was reachable. So I left it there and monitored things, but it wasn't long before I started seeing failed commands again.
In checking z-seer+ where you normally get a number 1, 2 or maybe even 3 showing how many hops it takes to get to the controller on this new device I don't see any of those. Previously to the upgrade most devices had a direct connection with maybe 2 needing 1 hop and another 1 needing 2 hops. Also in the homeseer plug-in which checking the node information there isn't an option to Set Route and there were no devices showing a last working route. I'm going to maybe see trying to replace one of the other 2 z-nets this weekend and see if I have any better luck, but wanted to know if anyone else has one installed and if they are seeing any issues.
Where normally I see maybe 2 or 3 Failed sending commands in a day with the new z-net I was getting closer to 100 a day and that was with very low activity in the house at the time.
I'm running on:
HS4 Pro 4.2.16
z-wave 3.0.11.0
Jeff
I'm running on:
HS4 Pro 4.2.16
z-wave 3.0.11.0
Jeff
