I'll try to confirm this when I get home.
Sound off! Who wants an European version - Now Available!
Running on Windows 10 (64) virtualized on ESXi (Fujitsu Primergy TX150 S8).
OK - I did a lot of testing with a Euro Z-Net device this morning. See bottom of email for my setup. Here's what I found when testing:
On loss of network or power:- Generally the Z-Net would power back up, and have a solid RED light on the LED.
- There is NO warning in the log or on the ZWave controller management page that connection was lost to the interface
- Conversely the plug-in does not appear to periodically check/establish connection
- The first command, sent from a device management page, results (expectedly) in an Unknown status to that device.
- However, this also causes the plug-in to re-establish connection (LED goes GREEN) and subsequent commands works and results in correct status on Device Management page
It would be great to have logging / alerting that could be triggered etc. for the connection. Perhaps the Z-Net Node 1 device could be used for connection status and connect/disconnect buttons?
HOWEVER, I did find that, on occasion, when the power was pulled (unplug PSU and plug it back in again), the Z-Net would NOT boot correctly. You can see this by the LED not coming (no red, green or blink or anything) although the smaller internal LEDs are on (so there is definitely power to the device). In these instances you also could not ping the Z-Net. The only way to fix this is to powercycle the device again.
I found the above condition to occur both when testing with the US supplied PSU and when testing with a UK PSU (supplied by a Raspberry Pi supplier who claims their PSUs are good for use with PIs). Mentioning this as I am trying to rule out a PSU issue here.
The failure rate for the above was about 2 in 10
This to me is somewhat concerning as this is difficult to remotely address and could result in the need to do a call out to a customer site.
Test Rig Setup:
Current Date/Time: 16/10/2015 11:57:29
HomeSeer Version: HS3 Standard Edition 3.0.0.208
System Uptime: 0 Days 3 Hours 14 Minutes 54 Seconds
IP Address: 192.168.1.50
Number of Devices: 290
Number of Events: 8
Enabled Plug-Ins
3.0.1.25: Z-WaveNicolai L
Originally posted by NicolaiL View PostHOWEVER, I did find that, on occasion, when the power was pulled (unplug PSU and plug it back in again), the Z-Net would NOT boot correctly. You can see this by the LED not coming (no red, green or blink or anything) although the smaller internal LEDs are on (so there is definitely power to the device). In these instances you also could not ping the Z-Net. The only way to fix this is to powercycle the device again.
... and did you try with beta version .39 of the Z-wave plugin?HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Originally posted by NicolaiL View PostOK - I did a lot of testing with a Euro Z-Net device this morning. See bottom of email for my setup. Here's what I found when testing:
Test Rig Setup:
Number of Events: 8
Enabled Plug-Ins
3.0.1.25: Z-Wave
I also noticed the random refusal to boot after power was cut / restored but forgot to mention it yesterday. I didn't test the reconnection after a failed send until today but I can confirm that the Z-Net does re-connect as you say following a failed command initiated from HS3.
Paul..
Test Rig Setup:
Number of Events: 8
Enabled Plug-Ins
3.0.1.25: Z-Wave
If your power stability is bad, consider adding some protection for this. Obviously, your HomeTroller will be at risk too. consider adding a UPS to the equation since both of the items are computers!Last edited by macromark; October 16, 2015, 03:03 PM.
Originally posted by macromark View PostDon't get too hung up on the red/green light status of the box. We intentionally do not have the plug-in bombard the unit with continuous connectivity checks to avoid performance issues. If you disable and then re-enable the plug-in, it will force a check but physically disconnecting/reconnecting or power-cycling the unit will not. Sending a command will also force a check. It does take about 20 seconds to boot the box from a powered-off state.
To be honest, I haven't used ethernet equipment that doesn't handle disconnects and power dropouts before. I took it for given...
Finally, you can use the device created for the Z-wave controller for something! Status codes!
That way, I can set up Events to notify me if the Z-net goes offline.
Yes, I can add an UPS, but that isn't always an option as the server is far away from the Z-NET (that's the point!).
Originally posted by Moskus View PostYou don't need to "bombard the unit" with connectivity checks, but you still need to do some automatic checks!! My guess is that a simple ping will do, say every 5 or 10 seconds.
HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
Google Search for HomeSeer Forum
I don't have unstable power, but inevitably people have power cuts from time to time. My concern is the failure to boot, because this is the type of condition that is very unfortunate for a customer install and will almost certainly result in a support call / unhappy customer.Nicolai L
These are my main controllers, Z-wave and RFXCOM:
The RFXCOM devices (both via ethernet and USB) quickly show their status, like this:
Much better than "No Status"...HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
The Arduino plugin also handles this seamlessly and fast.
As do UltraJones' Global Cache plugin. And the Squeezebox plugin (although, it has a Logitech server application to support it).
I have purchased a US Znet and 2x EU Znet. Unforunately somewhere along the shipping route, the (pretty thin) boxes spilll their znet content, so I'm having difficulties telling which ZNET unit is EU or US.
I've scoured the plastic casing and stickers and still couldn't tell which is which, since there are no markings of EU/US version, except for the sticker on the spilled boxes. I was hoping the information would presetn itself on the web admin, maybe by different firmware version or region string, but nope.
The only difference I could see is that the label is upside down on one of them. Could this be the US version? Can anyone help me tell which is which?HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
Originally posted by LeoS View PostI have purchased a US Znet and 2x EU Znet. Unforunately somewhere along the shipping route, the (pretty thin) boxes spilll their znet content, so I'm having difficulties telling which ZNET unit is EU or US.
The only difference I could see is that the label is upside down on one of them. Could this be the US version? Can anyone help me tell which is which?sigpic
