I have a check mark in:
Enable remote access through MyHS service
Docfxit
Docfxit
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
Sep-21 23:33:03 | Info | System connected to MyHS Service successfully with license ID XXXXX. |
Sep-21 23:33:03 | Info | System connected to MyHS Service, waiting for acknowledge... |
Sep-21 23:33:03 | Info | Starting the MyHS Service... |
Sep-21 23:32:56 | Info | Stopping the MyHS Service... |
[h=1]Server Error in '/' Application.[/h] [HR][/HR][h=2][I]Validation of viewstate MAC failed. If this application is hosted by a Web Farm or cluster, ensure that <machineKey> configuration specifies the same validationKey and validation algorithm. AutoGenerate cannot be used in a cluster. See http://go.microsoft.com/fwlink/?LinkID=314055 for more information.[/I][/h] [FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif][B]Description: [/B]An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. [B]Exception Details: [/B]System.Web.HttpException: Validation of viewstate MAC failed. If this application is hosted by a Web Farm or cluster, ensure that <machineKey> configuration specifies the same validationKey and validation algorithm. AutoGenerate cannot be used in a cluster. See http://go.microsoft.com/fwlink/?LinkID=314055 for more information. [B]Source Error:[/B] [/FONT] [TABLE] [TR] [TD][FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif]The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL: 1. Add a "Debug=true" directive at the top of the file that generated the error. Example: <%@ Page Language="C#" Debug="true" %> or: 2) Add the following section to the configuration file of your application: <configuration> <system.web> <compilation debug="true"/> </system.web> </configuration> Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode. Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario. [/FONT][/TD] [/TR] [/TABLE] [FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif][B]Stack Trace:[/B] [/FONT] [TABLE] [TR] [TD] [FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif] [ViewStateException: Invalid viewstate. Client IP: 70.235.112.106 Port: 18921 Referer: https://myhs.homeseer.com/ Path: /login.aspx User-Agent: Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:56.0) Gecko/20100101 Firefox/56.0 ViewState: /wEPDwULLTEyMDM3NzA2NDQPZBYCZg8PFgQeD19fQW50aVhzcmZUb2tlbgUgYjZkYTNiNDA3YzkxNDQxMjlmYWNkM2ViYmMwMWU0OGYeEl9fQW50aVhzcmZVc2VyTmFtZWVkFgICAw9kFgICAw9kFgQCBQ8WAh4EVGV4dAUYSG9tZVNlZXIgaXMgbm90IHJ1bm5pbmcuZAIKDxYCHwIFATRkZKAHIAVrIcX7qEIA8vs3ZDmaI8ASygAVZaxX6AVL/diW] [HttpException (0x80004005): Validation of viewstate MAC failed. If this application is hosted by a Web Farm or cluster, ensure that <machineKey> configuration specifies the same validationKey and validation algorithm. AutoGenerate cannot be used in a cluster. See http://go.microsoft.com/fwlink/?LinkID=314055 for more information.] System.Web.UI.ViewStateException.ThrowError(Exception inner, String persistedState, String errorPageMessage, Boolean macValidationError) +116 System.Web.UI.ObjectStateFormatter.Deserialize(String inputString, Purpose purpose) +425 System.Web.UI.ObjectStateFormatter.System.Web.UI.IStateFormatter2.Deserialize(String serializedState, Purpose purpose) +13 System.Web.UI.Util.DeserializeWithAssert(IStateFormatter2 formatter, String serializedState, Purpose purpose) +40 System.Web.UI.HiddenFieldPageStatePersister.Load() +248 System.Web.UI.Page.LoadPageStateFromPersistenceMedium() +251 System.Web.UI.Page.LoadAllState() +36 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +6712 System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +245 System.Web.UI.Page.AsyncPageProcessRequestBeforeAsyncPointCancellableCallback(Object state) +16 System.Web.HttpContext.InvokeCancellableCallback(WaitCallback callback, Object state) +85 System.Web.UI.Page.LegacyAsyncPageBeginProcessRequest(HttpContext context, AsyncCallback callback, Object extraData) +255 System.Web.UI.Page.AsyncPageBeginProcessRequest(HttpContext context, AsyncCallback callback, Object extraData) +97 ASP.login_aspx.BeginProcessRequest(HttpContext context, AsyncCallback cb, Object data) +97 System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +103 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +155 [/FONT] [/TD] [/TR] [/TABLE] [FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif] [/FONT] [HR][/HR][FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif] [B]Version Information:[/B] Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.7.2106.0 [/FONT]
[COLOR=#000000]System connected to MyHS Service successfully with license ID XXXXX.[/COLOR]
[h=1]Server Error in '/' Application.[/h] [HR][/HR][h=2][I]Validation of viewstate MAC failed. If this application is hosted by a Web Farm or cluster, ensure that <machineKey> configuration specifies the same validationKey and validation algorithm. AutoGenerate cannot be used in a cluster. See http://go.microsoft.com/fwlink/?LinkID=314055 for more information.[/I][/h] [FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif][B]Description: [/B]An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. [B]Exception Details: [/B]System.Web.HttpException: Validation of viewstate MAC failed. If this application is hosted by a Web Farm or cluster, ensure that <machineKey> configuration specifies the same validationKey and validation algorithm. AutoGenerate cannot be used in a cluster. See http://go.microsoft.com/fwlink/?LinkID=314055 for more information. [B]Source Error:[/B] [/FONT] [TABLE] [TR] [TD][FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif]The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL: 1. Add a "Debug=true" directive at the top of the file that generated the error. Example: <%@ Page Language="C#" Debug="true" %> or: 2) Add the following section to the configuration file of your application: <configuration> <system.web> <compilation debug="true"/> </system.web> </configuration> Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode. Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario. [/FONT][/TD] [/TR] [/TABLE] [FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif][B]Stack Trace:[/B] [/FONT] [TABLE] [TR] [TD] [FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif] [ViewStateException: Invalid viewstate. Client IP: 70.235.112.106 Port: 62633 Referer: https://myhs.homeseer.com/ Path: /login.aspx User-Agent: Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:56.0) Gecko/20100101 Firefox/56.0 ViewState: /wEPDwULLTEyMDM3NzA2NDQPZBYCZg8PFgQeD19fQW50aVhzcmZUb2tlbgUgMjJkMjc0ZGIwOTVmNGQwMjg4ZDE0NmJiODA4MDUwMzIeEl9fQW50aVhzcmZVc2VyTmFtZWVkFgICAw9kFgICAw9kFgQCBQ8WAh4EVGV4dAUYSG9tZVNlZXIgaXMgbm90IHJ1bm5pbmcuZAIKDxYCHwIFATRkZMc2gW+GlOAwHLzEd7I841qSQ9YwkP7mIwSU/57AR3Q5] [HttpException (0x80004005): Validation of viewstate MAC failed. If this application is hosted by a Web Farm or cluster, ensure that <machineKey> configuration specifies the same validationKey and validation algorithm. AutoGenerate cannot be used in a cluster. See http://go.microsoft.com/fwlink/?LinkID=314055 for more information.] System.Web.UI.ViewStateException.ThrowError(Exception inner, String persistedState, String errorPageMessage, Boolean macValidationError) +116 System.Web.UI.ObjectStateFormatter.Deserialize(String inputString, Purpose purpose) +425 System.Web.UI.ObjectStateFormatter.System.Web.UI.IStateFormatter2.Deserialize(String serializedState, Purpose purpose) +13 System.Web.UI.Util.DeserializeWithAssert(IStateFormatter2 formatter, String serializedState, Purpose purpose) +40 System.Web.UI.HiddenFieldPageStatePersister.Load() +248 System.Web.UI.Page.LoadPageStateFromPersistenceMedium() +251 System.Web.UI.Page.LoadAllState() +36 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +6712 System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +245 System.Web.UI.Page.AsyncPageProcessRequestBeforeAsyncPointCancellableCallback(Object state) +16 System.Web.HttpContext.InvokeCancellableCallback(WaitCallback callback, Object state) +85 System.Web.UI.Page.LegacyAsyncPageBeginProcessRequest(HttpContext context, AsyncCallback callback, Object extraData) +255 System.Web.UI.Page.AsyncPageBeginProcessRequest(HttpContext context, AsyncCallback callback, Object extraData) +97 ASP.login_aspx.BeginProcessRequest(HttpContext context, AsyncCallback cb, Object data) +97 System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +103 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +155 [/FONT] [/TD] [/TR] [/TABLE] [FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif] [/FONT] [HR][/HR][FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif] [B]Version Information:[/B] Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.7.2106.0 [/FONT]
