No devices on HS Mobile - Solved!
    I have also sent feedback through the app but I figured I would post here as well.
    Installed HomeSeer Mobile on Google Pixel XL (Gen 1). I have tried several times; however, no devices will display. "Location list not loaded"  is displayed when I tap on room or floor filters. The events list is populated which I assume confirms connectivity.
    This is my first time trying HS Mobile, however I did Uninstall, clear data, cache etc to try and resolve.
    HSM Version: B0.3.9
    LicenseID: XXXXX
    HS3 Version: 3.0.0.478
    Connected Locally
    Sent from my Pixel XL using Tapatalk
    Have you tried clicking on the Floor and Room buttons and selecting ALL?
      Hi, per my original post:
      I do not get any pop ups or options to select ALL
      ~ Donald
      Minnesota USA
        Have you verified that the devices are not hidden from mobile view? Open a device in the web interface and on the Configuration tab, clear "Hide device from mobile views:" checkbox if it is selected.
          I have checked a device and that box is not checked. My refid count is up around 800 so I have plenty of devices.
          One thing I discovered just now, if I open the app and go to the devices page, click the right menu and refresh all of my devices show up. The floor and room button show the same message as list not loaded.
          If I close the app and reopen the list is empty again
          ~ Donald
          Minnesota USA
            Here is a screen capture of what I am seeing.
            https://youtu.be/6KhyZ2L_qUA
            ~ Donald
            Minnesota USA
              I guess I am looking at a server side issue. I have the same exact problem in the iOS beta.
              Any thoughts on this or what to check?
                I figured it out, well kind of.
                I cleaned up 20 orphaned or unused devices and removed an old plugin I’m no longer using (MQTT) and everything works as expected now.
                Not sure what the root cause was but this seems to have solved it.
                  I have the same problem. Have tried some cleaning, but did not restart from scratch.
                  No success: “locations are unavailable” although events and cameras show up.
                  Anyone know what it may be sensitively to?
                    HomeSeer Mobile does not cope well with invalid devices. If you delete 5 devices from HomeSeer for example four of them will jam HomeSeer Mobile big time but you will be able to get rid of them, but one will be totally stuck - no amount of tapping on it will let you do jack. I have several such stuck devices - on a few occasions I have cleared the whole dashboard and reconstructed the darned thing to get rid of them, but the last time I got one stuck (greyed out and invalid, doesn't respond to touch) I've now just left it as I can't be bothered going through the whole rebuild thing
                    What the actual?!? When I make a sarcastic remark or joke it is moderated/deleted.
                    But you specifically go out of your way to label multiple HS4 issues that cause data loss/crash of HS4 to be "grumbles".
                    I can't even begin to put into words how offensive this is.
                      I am also getting this error:
                      Unexpected character encountered while parsing value: E. Path ", line 0, position 0.
                      I have tried to apply this fix without success: https://forums.homeseer.com/node/123...77#post1241477
                      -I went to setup in HS (network tab) and unchecked and rechecked the "Enable remote access through MyHS service" checkbox.
