HomeSeer Mobile Beta V 1.0.2 (9) (IOS)
This topic is closed.
    HomeSeer Mobile for IOS is ready for testing!
    To test, install the TestFlight app on your IOS device and use this link to join the Beta:
    https://testflight.apple.com/join/YChZViLH
    Note the following:
    • Supports iOS 9.3 or later
    • Supports iPhone, iPad, and iPod Touch devices, although screen formats are optimized for the iPhone
    • You will need to install the latest Beta of HS3 on your PC or controller, get it from here:
      https://forums.homeseer.com/forum/ho...-release-notes
    Known Issues:
    • When resizing dashboard widgets the controls may not resize properly. To work around, refresh the view by either switching to another dashboard or another view.
    • On IOS 9 the search bar on the devices page is not displayed. The search bar we are using is only available in later IOS versions. The filters still work however.
    • When editing a thermostat widget, hiding the controls is not honored.
    • The error message about a system not being the right version incorrectly prepends "3.0.0." before the full required version.
    • On the device list, some devices may not display all of the controls. Click on the device to get the full controls array.
    • On the login screen, on some iPhone models, the password field is hidden.
    Our HomeSeer Mobile docs have been updated to reference the IOS changes here:
    https://helpdesk.homeseer.com/catego...omeseer-mobile
    Please post any issues or feature requests you might have to this forum.
    Hi, I've done everything but when entering TestFlight I still need a redeem code. Did I miss something?
      The redeem code is displayed when you click the "View in Testflight" button in the email sent to you.
      - JL West
      HomeSeer Software Engineer
        I clicked the "view in Testflight" button in the e-mail. Not asked for a redeem code.
        John
          @iOS 12.1
          Trying to add a device to the dashboard. However no device is shown in the app. Events are displayed correctly.
          At start up devices where shown and the filters were visible. Selecting a filter resulted in this screen.
          How to navigate back?
          Click image for larger version  Name:	Capture devices.PNG Views:	1 Size:	209.6 KB ID:	1257797
          John
            Click image for larger version  Name:	File Nov 07, 12 24 48 PM.jpeg Views:	1 Size:	130.3 KB ID:	1257802
            I have a valid LetsEncrypt certificate, and browsers have no problems validating the cert when I connect to my HS3 URL (same URL I have entered in the "hostname" field of HS Mobile).
              Originally posted by John245 View Post
              @iOS 12.1
              John
              Logged in again and it is working.
              John
                I got the same issue, my plugin root is in room "equipment" and all my child of the plugin are in they appropriate room (ex. Kitchen), so when I want to see the kitchen room it don't show my device. To see my kitchen device I need to go to the room of the root of the plugin, in the equipment.
                We should be able to have the device in they appropriate room and not have to go to the room of the main root.
                @iOS 12.1
                John
                  We want to get away from separating child devices from the root as for most users and devices, the child device is always physically part of the actual hardware. So what device is this where you want the child device in different rooms? Are your rooms of the type "sensor" or some other type where segregating the child devices makes sense?
                    I'm in, and besides the known issues listed it is working nicely.
                    HS Install Date: Feb. 16, 2007
                    HS3 Pro, Z-Wave, Insteon, BLStat, HS Touch Server, MyQ
                    WeatherXML, BLBackup, BLLAN, BLLock, Restart, CaddX, OpenSprinkler
                      Than I have a big issue.
                      I separated all my root Z-wave devices from my child devices.
                      In my case the set-up for the root devices is:
                      Location 1 is defined as: [Z-wave protocol] [SDK]
                      Z-wave protocol could be Z-wave or Z-wave plus
                      Location 2 is defined as [Manufacturer] [type]
                      The set-up for the child devices is:
                      Location 1 is defined as [system], system could be for example ventilation
                      Location 2 is defined as [room]
                      The benefit of this is that I can simply inventarize which nodes are available and where these are located.
                      John
                        Initial feedback: pretty snappy, loving the response time.
                        Mike
                          It takes 53 seconds before the connection is made with the HS Mobile app. While this takes only 20 seconds with the HS3Touch mobile app. 1371 devices and 168 events.
                          John
                            Rich,
                            All the Lutron are for whole house system, so do you suggest I remove the parent and child from my plugin?
                            Also other plugin will have the same issue as the AmbientWeather that I have some sensor in my home to monitor the temp and humidity in some room
                            This mean I'll lost the group with my plugin if I remove the parent and child? This would be bad news
                              Not able to login but that could be for many reasons...
                              Rich, does HS Mobile need the ability to ping the network subnet gateway? I block that ability for security reasons. Maybe that is one of the reasons to why I can't log in.... If you could confirm either way that would be great.
                              Thx.
