Unable to edit Foscam log in info
  • Unable to edit Foscam log in info
    I have 6 Foscam cameras I am trying to activate in HS Mobile. HS3 sees them fine. I am trying to enter my user and password through the HS3 Setup/Camera tab. I have successfully entered 4 cameras. But the remaining cameras I am unable to access the edit screens for user or password. They seemed to be locked. I have rebooted HS and rebooted the cameras. No success.
    Any ideas? Is there a way to edit the configuration file with this info>
    Have a look at the hspi_HSTouch.ini file in the config directory of HS3 and try clearing the non working cameras here and see if adding them back solves this.
    -Rupp
      Tried editing the config file. Not change in camera setup. How can I reset it all? Delete config file?
        Figured out the issue. I had several cameras with the same camera name. As such I could not edit these even though they all had unique IP addresses. By renaming the cameras with unique names all is normal now.
