SSL - Not connecting via mobile but ok via Safari
    Hello,
    On an iPhone 7 plus
    SSL(TLS) will not connect via Homeseer Mobile, however Safari connects using https(SSL/TLS) just fine.
    OK I'm using the self signed cert... is this the reason, if so can we please have an override?
    John
    Yes it seems like HS Mobile will not connect directly via SSL? I am in an identical situation. I tried self signed and a paid certificate and it still won't connect. It seems others are also unable to connect via SSL. Can someone please advise if this is a bug? What is the way forward thanks...
      Same here, it’s been like this since the app came out. HS3TOUCH works fine.
      Cheers
      J
        Several posts without resolution.
          Not sure if this is the same issue, but I have been unable to connect through the mobile app for several days. I can connect directly though on the local network.
