So after leaving it a whole month, I thought I would contact support again.
First response from support was
“There has been an update released for the app, please check and make sure that you are running the latest version and test the app again. If it is still not working, then you may need to uninstall and re-install the app.”
My response to that
“No there hasn't. Check lower in the thread 1.1.4”
Their final response
“Unfortunately, you will need to uninstall and re-install the app as I am not sure when the next update will be released.”
So they aren’t going to update, there still is no backup feature. Yet another HomeSeer product heading for my bin.
Cheers
J
Problems with ver 1.1.4 for iOS
Originally posted by Steve Q View PostI still have my iPhone version and a older version on another iPad. They are still working.
Hopefully I will be able to recover my dashboards. I will wait for the new version.
Without backup/restore capability, I will not invest anymore effort on the mobile version.
Cheers
J
Originally posted by Steve Q View PostI’m extremely dissapointed, once again, I have lost all my dashboards in HS Mobile. I have put a lot of work into HS mobile. Lost it all!
I have just left the app alone, did you delete it? Once update comes they should still be there.
Cheers
J
Getting a ton of messages in my HS3 log. I don’t recognize this IP address.
Originally posted by randman View PostHomeSeer Mobile was working fine for me, until this morning, when I brought it up and got the attached error. I restarted HomeSeer Mobile a couple of times (swipe up), but didn't help. I'd get the same error on every attempt to start it. Only solution was to remove the app and reinstall (losing my dashboards in the process).
Cheers
J
1 Photo
I still cant login with direct IP and now I cant login at all on myhomeseer as the login screen is broken. I don't want to lose my dash board either :/
Cheers
J
Thanks for the release of ver 1.1.4 with the new login page. I downloaded it on my iPad Air 2. But there is a big problem! I can login (via IP) without entering a username or password!
And yes now the old dashboards which had previously disappeared are back. However, it appears that the dashboards from my iPad Pro (still using 1.1.3) have been consolidated into version 1.1.4 on the iPad air2. This may be OK if that was your intention, but I was under the impression that HS Mobile was device specific. (Every iOS device had its own dashboards).
Please, please, please, post the release information on this board when you release an update.Tags: None
