Can remove visual element on widget
    Hi. I’m trying to remove one of the visual elements of a device after I added it to my dashboard. As you can see in the first pic, the light on right has a horizontal line in the widget. I tried to go into the widget and disable it but me tapping the first visual element doesn’t do anything. It used to turn the color red once I tapped on it to disable. I went into the other light and it’s disabled but I can’t even toggle it anymore. These are the same device types. It worked a few weeks ago but now I can’t toggle seem to toggle it regardless on either device.
    Thoughts ?
    Anyone have any ideas?
      It's a bug, this happens to me a lot - you toggle one of those elements on or off and the screen does not respond. However it HAS changed state configuration wise the GUI just hasn't reflected - Hit Save and the widget does change to no longer have on or off. Inconsistent and very annoying quirk, but you get used to it.
      Assuming same issue of course...
      What the actual?!? When I make a sarcastic remark or joke it is moderated/deleted.
      But you specifically go out of your way to label multiple HS4 issues that cause data loss/crash of HS4 to be "grumbles".
      I can't even begin to put into words how offensive this is.
        I just tried tapping it and hitting Dave and unfortunately it doesn’t change when you
        Go back to the dashboard.
