Can't connect to Hometroller Zee V2
    Hi, I'm unable to connect HomeSeer Mobile to my Hometroller Zee V2. When I try to login in using DDNS, I get the previously stated Unknown error. When trying to login using local IP + port 10200 I get this in the HS log:
    Mar-08 09:23:14 HSTouch Server Client has DISCONNECTED.
    Mar-08 09:23:14 HSTouch Server Client (192.168.77.100/56227) has raised LineDisconnected or was forced closed.
    Mar-08 09:23:14 HSTouch Server Warning Client dropped connection 192.168.77.100/56227
    Mar-08 09:22:54 HSTouch Server Debug 09:22:54:5910 ~ Adding client 192.168.77.100 to client table with key 55
    Mar-08 09:22:54 HSTouch Server Opening connection from:192.168.77.100/56227
    Mar-08 09:22:54 HSTouch Server Debug 09:22:54:5891 ~ Removing dead connection: 53
    And the app just goes back to the login screen. I'm using my iphone and on HS Mobile version 1.1.4. I've tried both and admin user and and a guest user, same log. I tried to download HS Mobile on my Samsung tablet, but it says it's not compatible (probably due to old Android system). Anything else I could try?
    Current Date/Time: 3/8/2019 9:16:44 AM
    HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.500
    Linux version: Linux HomeTrollerZeeS2V2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux System Uptime: 26 Days 19 Hours 59 Minutes 26 Seconds
    IP Address: 192.168.77.200
    Number of Devices: 88
    Number of Events: 49
    Available Threads: 389
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    Enabled Plug-Ins
    3.0.1.125: PHLocation
    0.0.0.45: Pushover 3P
    3.0.1.252: Z-Wave
