Wyze Cam with HS mobile
  • Wyze Cam with HS mobile
ID:	1304129Wyze Cam has introduced RTSP firmware for their extremely popular Wyze camera. This can be downloaded from their site and installed on version 2 cameras. The RTSP feed from the camera is compatible with HS3 and can be directly added to the camera setup page in HS3. Once added to HS3, it can be also be added to the camera page of HS mobile. You can then create dashboards which include the Wyze Cam stream.
    Do you need an account any longer to use these?
    Sent from my SM-T813 using Tapatalk
      Yes you need to register the Cams. You need the Wyze app to view the cameras and set them up. You also need the app to view recorded video. But once RTSP firmware is installed on the camera, you can use local software to record and view the stream. I use NetCam Studio. But I will continue to use the Wyze app for firmware updates.
        My RTSP stream from my Wyze Camera is no longer showing up in HS3 mobile. I believe it stoped working when I upgraded to HS3 version 531. Is anyone else having an issue with RTSP Camera feeds?
          Can't seem to get my feed working either.. Did you ever get this fixed?
          Im on the latest version of HS3 (.534) and the RTSP in active on my Wyze Pan cam.
          The rtsp feed works in VLC without any issues.
            I am still not able to get The RTSP feed from my Wyze Cam to show in HS3 mobile.
              Is the Wyze cam working on mobile again? It's really weird how the RTSP feed no longer works?
                I would like to try again but I can’t find my notes on the HS3 config command line for the Wyze Cam. Can someone provide this?
                  Does anyone have HS3 mobile working with An RTSP Camera?
