Very odd behavior. I noticed in the log after using HS Mobile events like:
May-14 8:01:56 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 8:01:32 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 8:01:30 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 8:01:15 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 8:01:14 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 8:01:02 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 8:00:57 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 8:00:52 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 8:00:47 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 8:00:42 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 8:00:37 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 8:00:32 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 8:00:17 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 8:00:12 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 8:00:07 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 8:00:02 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:59:57 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:59:54 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:59:44 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:59:37 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:59:12 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:59:07 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:59:04 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:58:55 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:58:51 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:58:46 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:58:29 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:58:24 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:58:19 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:58:13 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:58:08 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:57:30 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:57:27 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:57:05 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:57:00 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:56:55 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:56:50 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
May-14 7:56:49 AM Web Server Web Server authorized login successful from: xx.xxx.xx.xx User: r***a@comcast.net
xx.xxx.xx.xx is my publice WAN address.
Happens every time I log in. Seems like these events are taxing the server and it is generally slow e.g. log page refreshes and generally cannot login through MyHS due to timeouts. I was successful once. Since myHS is not working I connect direct with DNSname_port which connects to the Zee server on a subnet.
HS Mobile connects every time and very quickly. Trying to connect with same DNSname_port usually results in a timeout. Smartphone and PC/Chrome Browser are on the same LAN.
So...any ideas?
Thanks.
Further update:
When first logging into HS Mobile three login events are logged. If I do nothing with the app, the Log file is quiet.
However, each time I activate a widget (On/Off, click on it to view,...etc) more login entries are created.
HS support says this is not normal and they have not heard of this issue previsouly.
So...any ideas?
Thanks.
Further update:
