Mobile Event Widget Button (without Run Event/Edit Widget/Delete Widget option)
    I am trying to create an Event Widget that is strictly a button to manually trigger an event. However, I cannot find a way to configure that event widget such that the "Run Event/Edit Widget/Delete Widget" options don't pop up. I've tried single taps, long taps, double taps, etc. I've turned off Confirm before control"....all with no luck. Is there a way to create an event widget so that it is just a button, you tap it and it runs the event without any other user input required?
    Thanks in advance for any guidance.
    Current Date/Time: 5/20/2019 11:22:56 AM
    HomeSeer Version: HS3 Pro Edition 3.0.0.531
    Operating System: Microsoft Windows 10 Home - Work Station
    System Uptime: 0 Days 2 Hours 54 Minutes 36 Seconds
    IP Address: 192.168.1.48
    Number of Devices: 234
    Number of Events: 23
    Available Threads: 200
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    In Virtual Machine: No MFG: parallels software international inc.
    Enabled Plug-Ins
    3.0.0.64: EasyTrigger
    3.0.0.32: Ecobee
    2.0.3.2: JowiHue
    0.0.0.45: Pushover 3P
    3.1.0.28: Sonos
    I would create a simple virtual device that you have on the dashboard. When that button is pressed, have it trigger your event to run. You might have to make the trigger so that any value change will trigger the actions.
    68 Z-Wave Nodes, 175 Events, 359 Devices
      That worked great. Thanks for the suggestion!
