Plans for HomeSeer Mobile?
  • Plans for HomeSeer Mobile?
    Can someone of HomeSeer please explain a little bit of the plans for the HomeSeer Mobile app?
    So far I think this app has a lot of potential, but the app has still a lot of bugs.
    Is this app supposed to work for HS3, or is it targeting HS4?
    I can only use the app local connected to the IP of my HS3 Pro installation, but I want to connect directly via SSL and a DNS name. This is woking fine via a browser, but not with the HomeSeer Mobile app.
    This is makes the app unusable and I don’t understand why this is not getting fixed.
    Could someone related to HomeSeer please respond to this question?
      I think you will find that all Homeseer staff resources are being taken up with the development of HS4......
      Jon
        I'm not that technical on this stuff.... but thought id just chime in... and you didn't really say any of these... so just curious.. things to run through your thoughts..
        all I know is I can get to my system inside and outside of my house..
        so can you access via your cell phone outside of the house via web page?
        what happens if you go to myhs.homeseer.com and login?
        I see there is a myhs premium ... look through what it gives... - https://shop.homeseer.com/products/myhs
        free myhs.homeseer.com - you have to register.. did you do that? - https://shop.homeseer.com/pages/myhs...access-service
        hope that just starts you at the basics you may have already done....
          Well, I am a technical guy😁
          I don’t want to use the cloud connection service, I want to work with a direct connection to my HS installation. I am using a reverse proxy with SSL offloading to connect to my HS installation.
          This is working fine locally LAN connected with a browser and also via the internet.
          The HomeSeer Mobile app is only able to connect directly to HS by using the local LAN ip-address, without SSL. A dns-name is not working, and SSL is also not working, not locally and not via the internet. These are bugs also mentioned by other users and need to be fixed.
          The app has a lot of potential, but is unusable at this moment for direct connections.
          I want to know if this is going to be fixed. If not (if this app is dead) then I have to search for other solutions.
          This question is very simple to answer for HomeSeer...
            gotcha.. yeah I'm using it with myhs .. I too am technical (in my area LOL)...
            and do not like cloud either; however, I don't mind this part of it.
              Please e-mail homeseer support. It is not sure that this thread will be read by homeseer.
              John
