Loading device status images fails
  • Loading device status images fails
    I don't really know when this problems started, which makes it harder to determine what's causing it.
    If I open the device list as usual, all devices loads just fine. But then HS Mobile starts to download the status images, and I've met with a message that says: "We are having a difficult time talking to HomeSeer..." and when I click "Details" it says: "An unexpected error has occured. Object reference was not set to an instance of an object" (which, as always, makes things 100% clear).
    The missing icons are then replaced with questionmarks.
    Click image for larger version  Name:	Q2vh2WE.jpg Views:	0 Size:	35.5 KB ID:	1341169
    The graphics on the first panel loads just fine, so I'm guessing there's some device that is causing this problem. But how do I find that device?!
    I've turned on logging, but I can't find the log file...?
    Anyone...?
