Off on widget how to toggle
  • Off on widget how to toggle
    On the ios mobile app I have a handful of off on switches they display the status OK but how do you toggle the switch?
    I don't have the ios app, but on android I hold the widget until a menu pops up. Hit 'Edit Widget', scroll down and check the 'Use as toggle' box or 'Show Controls'.
      I don't know how to operate the device switch from the dashboard either. I have a hard time believing that I have to open the device to operate a switch.
        Once you edit the widget as instructed in post #2 above, it will function as an on/off toggle on a single-click, provided you also uncheck "confirm control".
        -Wade
          There is also a Show Controls option which will enable/disable the On and Off buttons as well as the dim slider and other appropriate controls. If both this and the Use As Toggle option are unchecked a pop-up appears when selecting a widget.
