Make device not visible in mobile?
    I have a few devices (mostly virtual devices) that I would rather not appear in the mobile app.
    Is there any way I can exclude them?
    I found the Hide from Mobile setting
      Here's a script that will hide all already hidden devices in the mobile view. Why they thought two "hide" functions was necessary is beyond me...
          Sub HideMobileDevicesIfHidden(input As String)
              Dim device As Scheduler.Classes.DeviceClass
              Dim DE As Scheduler.Classes.clsDeviceEnumeration
              Dim counter As Integer = 0
              hs.WriteLog("HideMobile", "Hiding hidden devices...")
              DE = hs.GetDeviceEnumerator()
              Do While Not DE.Finished
                  device = DE.GetNext
                  Dim isHidden As Boolean = device.MISC_Check(hs, HomeSeerAPI.Enums.dvMISC.HIDDEN)
                  If isHidden Then
                      counter += 1
                      device.MISC_Set(hs, HomeSeerAPI.Enums.dvMISC.HIDE_IN_MOBILE)
                  End If
              Loop
              hs.SaveEventsDevices()
              hs.WriteLog("HideMobile", "Hid " & counter.ToString() & " devices")
          End Sub
