HS Mobile Login
    HS Mobile Login
    I have just upgraded to HS4 -- everything was smooth, except HS mobile. I cannot log into my mobile app on android. I can log into myhs website (on and off home network). I am not sure what I need to do to access the mobile app?
    Any suggestions? Thanks
    Ditto... Precisely.
      Same here on IOS. I can log in when outside my WiFi range, but not when on my local WiFi network. My gut tells me its some configuration issue with my WiFi network. What sort of network are you running?
        I don't know if this will work for you but give this a try. Go to users in HS4, change the password of the user you are using in the Mobile App to the same password you use in myHS.homeseer.com
          I upgraded from HS3 to HS4. I had to update the license information in myHS to get it to work....
