Updater is missing from Plugins > Manage
    In Plug-Ins > Management, I don't have a option to access the updater. I was hoping to remove X10 and add the WeatherXLM plug-in.
    I updated to HS3 3.0.0.368 and Z-Wave 3.0.1.133 today which resulted in HSTouch showing now as Built-In. I have CM15A, HSInsteon and X10
    which I have never used and hoped to remove. I am pretty sure it has been there in the past. Thanks for any ideas. John
    Are there any errors in the HomeSeer log when you go to this page? Which browser are you using to view this page?
    -Rupp
      Updater
      Thanks for the reply. Log is clean. MS Edge and MS IE. Also just tried with Chrome and updater doesn't show there either. Could it be Browser settings?
        Downloaded Firefox and updater is still missing.
          Are you running on an original Zee unit or a newer Zee S2?
          -Rupp
            The original Zee unit.
              Rupp,
              Thank you for your replies. I believe my issue is due to a misunderstanding of the limitations of the Zee. I thought it had a limit of 5 plug-ins but it appears it is limited to the five default plug-ins it comes with. That’s why there is no updater. I had thought the updater would allow me to delete one of the three I don’t use and pick another one.
                HSTouch no longer takes up a plugin slot since it is built into HS now.
                You should be able to deselect any plugin and add any other that is supported on the Zee.
                68 Z-Wave Nodes, 175 Events, 359 Devices
                  A belated thanks for your reply, sir. Never did figure it out. Have moved to a HomeTroller Pi because the Zee was not upgradeable to HS4. It likely will work fine now.
