I have been trying for hours to log into my Hometroller Zee S2 using WinSCP. I have just downloaded and installed WinSCP onto my Windows 10 machine and the computer is on the same network as the Zee is on (both hardwired). I have HS3 ZEE S2 Edition 3.0.0.435 installed on the Zee.
No matter what username and password I enter, I cannot get it to connect. I have tried the username and passwords I set up when I set-up the Zee. I have even tried the default username (homeseer) and password (hsthsths3). I even tried setting up a new user with Admin + Local user rights under the Web/HSTouch User Settings. I made sure the file protocol was SFTP. The port name 192.168.1.185 is correct and the port number is 22. No matter what I do, I I keep getting "Access denied." I even tried logging in using the command window and SSH.
I can use a web browser to log into the Zee's web interface with no problem. I can also use HSTouch on my iPhone.
I have been searching the forums for a solution, but cannot seem to find a solution to my problem. Anyone have any idea what I might be missing?
