Since I've been having difficulties get my Zee to update it's version of Mono, it was suggested that I download the current Pi image from HomeSeer and image to a new card.
So first I backed up my Z-wave content on the controller page.
Then I backed up the HomeSeer config to my laptop.
I was able to get the new HS Pi image downloaded and imaged to a new SD card and swapped out the SD cards in the Zee.
The system came up and I logged in, re-registered and went into HS Setup and performed the Config restore.
It worked and rebooted.
And then I went into the Z-wave controller page and restored the Z-wave backup.
However, I'm having a few problems now.
a) only the X-10 and Z-wave plugins appear on the plugins page - no sign of EasyTrigger (registered) or EnvCanada plugins
b) on the Z-wave controller page, it shows me with two identical Z-wave controllers with an error message - images attached.
Questions
1) how can I remedy my Z-wave controller issues?
2) what happened to my 2 missing plugins - EasyTrigger and EnvCanada? Are plugins not automatically backed up inside the HomeSeer config backup?
3) if plugins aren't backed up in the HS Config backup - how else could you back them up?
4) if I switched to this newer version of the SD card, would I have to re-install those missing plugins? Is that "normal". I gotta be missing something.
Thank gawd, I can go back to the original (mostly) working card.
Cheers and Happy New Year everyone!
Questions
