After a restore, my events have bodies but no conditions or triggers?
    #16
    Now this is scary - I was able to launch your image, update it and then imported my year-end HS Config backup.
    And those events have no headers either!!!! Holy crap!
    I am going to try restoring earlier backups.
    Suggestions, voodoo, mystical spells are welcome
      #17
      What version of mono is on that image?
        #18
        Interesting 4.5.1
        Mine was running 3.2.8 at the time - maybe that explains why they're broken here, too?
          #19
          Yep. It was 4 that broke them. I don’t have any older images. Perhaps someone has an older image. The jump from 3 to 4 is what broke them, 4 to 5 is not a problem IIRC.
            #20
            Ahh, ok.
            Well, in my old image copy, I managed to remove the pieces of the old mono - now I just need to find the set of commands that will install that specific version of Mono on the card.
            Googling has indicated I should try something like this
            (I'm reaching for the 3.8 version because there is no 3.2.x in the repository)
            echo "deb https://download.mono-project.com/repo/debian wheezy/snapshots/3.8 main" | sudo tee /etc/apt/sources.list.d/mono-official-stable.list
            sudo apt-get update
              #21
              If your OS version is "jessie", the default mono build is 3.2.8. If its "stretch", you'll get 4.x something.
              So if it's jessie you're in luck. To check,
              more /etc/os-release
              If it says jessie anywhere in there you're good to go. If its stretch you'll have to set a repository as you found thru googling.
              If jessie, make sure that you've not set an alternate repository in /etc/apt/sources.list.d/, then install
              sudo rm -f /etc/apt/sources.list.d/mono*
              sudo apt-get update
              sudo apt-get install mono-devel mono-vbnc
                #22
                Thanks for those code snips but it's actually neither of those - it's something called "wheezy"
                PRETTY_NAME="Raspbian GNU/Linux 7 (wheezy)"
                NAME="Raspbian GNU/Linux"
                VERSION_ID="7"
                VERSION="7 (wheezy)"
                ID=raspbian
                ID_LIKE=debian
                ANSI_COLOR="1;31"
                HOME_URL="http://www.raspbian.org/"
                SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                And this is the Mono version I had (and trying to get back to)
                Mono JIT compiler version 3.2.8 (Debian 3.2.8+dfsg-4+rpi1)
                TLS: __thread
                SIGSEGV: normal
                Notifications: epoll
                Architecture: armel,vfp+hard
                Disabled: none
                Misc: softdebug
                LLVM: supported, not enabled.
                GC: sgen
                  #23
                  wheezy is even older than jessie. It's worth a try. Just run those three commands I posted. Won't break anything.
                    #24
                    Thanks for this. While I was very hopeful that it would reinstall Mono and that would fix things, that wasn't the case. Seems like other stuff was broken too.
                    I ended up abandoning any hope of updating that SD card with the proper Mono and getting things to the point where I could export my events for upgrading.
                    I have begun the painful process of re-entering my 250+ events into the new image/SD card and proceeding that way. I'm about 50% done.
                    It was a frustrating experience. Everything had been working fine under the old image/Mono except the Environment Canada plugin stopped working when Environment Canada switched to HTTPS feeds - which apparently didn't work under that old version of Mono.
                    And since I had been finding sooo much event-related functionality with that plugin - tying my sprinkler system and pool controls etc. to past, current and future weather values, I needed to go down that path to get it all working again....which it is, finally.
                      #25
                      I had this same problem and the solution was to rebuild the events as you have. It’s a painful resolution to this problem. I wish we could know when an update would have this affect.
                        #26
                        Misery loves company
                        But sorry to hear that you had to do the same thing.
                        At this point, I'm probably 80% through my rebuilds. The summer-specific ones can wait a bit. This morning it was -20C/-4F here.
