Building a graph (or report) with timers and counters
    Hello!
    I am wondering if anyone knows how to create a graph or report, like the built in Energy Graph, but for timers and/or counters? We have a gas heater and I have timers and counters that track its daily, weekly, monthly, and yearly time it is on. I know how much gas the heater consumes while it is on, and so if this was possible, I could easily track my gas consumption.
    Been searching through the forums, but nothing surfaced yet.
    Thanks for any help.
    Cheers,
    Bryan
    Hi Bryan, if you are on Windows, then this is a good option: https://forums.homeseer.com/forum/3r...for-homeseer-3
    Cheers
    Al
      sparkman Thanks Al! Unfortunately I am on a Mac. Havent used Windoze since XP...
        The "Device History" plug-in works well for this. Found under "Utilities" in the updater, by skWare.
        You can set it to monitor any device(s), including counters {I haven't tried it with timers - you'd probably need to update a different device with the actual timer duration you want to record before resetting it). You can create an on-demand graph from the web interface, and/or embed in HSTouch.
        Overall thread:
        https://forums.homeseer.com/forum/ul...-history-shill
        Thread discussing building graphs into HSTouch:
        https://forums.homeseer.com/forum/ul...istory-hstouch
        Another graphing example:
        https://forums.homeseer.com/forum/ul...ing-in-hstouch
        PS: I'm doing almost the same thing as your goal, but tracking how often the sump pump operates.
          NutsyHome - thank you so much for your help. This is very insightful, but unfortunately I don't use Windows, nor will I ever in the future. I am a Mac guy. Sadly this is not so important for me to pay for a Windoze license to run in a VM and drop the $199 for the HSTouch Designer License.
            If your intent is to manually create graphs on demand, you can do that directly from the Zee's web interface via the Plug-in menu for Device History... HSTouch is not required, it's just an alternate display option.
              Oh cool...how do I find this? I am on "Interfaces and Add Ons" and expanded "Additional Interfaces". Unfortunately I do not see a way to search for a plug in?
                Ah, never mind. Found it in "Utilities". I am guessing it is the one for $29.95 by skWare Technologies (shill) -- again, not so important to drop $30.
                Thanks again for your help. Really appreciate it...
                  Yes, "Device History" by skWare. It has a free trial so you can play around, read through his forum, and see if it suits your needs.
