Hi all,
I have decided to give HS another try in a small office building I own (house size at just 3000 SF) as a Zee. I currently use Smartthings there and it works reasonably well, but I want more control over rules/events than I can achieve with Smartrules and Smarththings, as the cloud processing is, admittedly, occasionally a problem. So, for “transferring” Z-wave switches, is there a process that must be followed? Specifically, must I remove the switches from Smarththings before adding them to Homeseer, or can I just leave them in Smarththings and unplug the Smartthings hub before turning on Homeseer and adding the switches, which would leave Smartthings as something to return to if I don’t like the Homeseer/Zee experience?
Thanks in advance for help and replies, and here’s to hoping this goes well... I was a raving fan of HS back in the old 1.x days, but much less so in later iterations. My lurking on the board now and then suggest that things seem to be better now than in past years (more stable), so I’m hoping to make my peace with HS again and return as a happy Zee user. And yes, I’m aware of the 5 plugin limit, etc.
