Raspberry
    Raspberry
    Hi, I do not know if this is the right place to answer my questions.
    I am trying to install HS3-Pi3 Smart Home Software on Raspberry PI 3 Model B +.
    I purchased the software and I have the license.
    I have downloaded the software, I have flash image on SD card.
    I put the card in Raspberry, I connected USB monitor and keyboard and give power.
    After a while, request loging ...
    Question: which loging should I use?
    Thanks in advance.
    Thanks in advance.
    In case you did the install for inexperienced Linux users just enter the IP address on an other system and it will guide you further.
    If you don’t know the up address use an IP scanner such as advanced IP scanner.
    John
      Thanks for your reply.
      I still do not understand.
      I have found a specific thread for HS3PI.
      I will formulate my questions there.
