Got my Hometroller Zee S2 up & running, but when I turn on the Z-Wave interface, it's not configured. I can't seem to get it to add an interface with any of the "interface model" selections.. Am I missing something?
Can't get Z-Wave to initialize
Here's the log file when trying to initialize:Jun-12 3:19:36 PM Z-Wave Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect. Jun-12 3:19:27 PM Z-Wave Error Internal: Cannot open COM port /dev/ttyAMA0, exiting. Ex=Input/output error Jun-12 3:19:26 PM Z-Wave Warning Internal: Cannot configure COM port /dev/ttyAMA0, will attempt an open. Jun-12 3:19:26 PM Z-Wave Warning ------------------------------------------------------------------ Jun-12 3:19:26 PM Z-Wave Warning - Z-Wave Transmit/Receive thread was not running - restarting... - Jun-12 3:19:26 PM Z-Wave Warning ------------------------------------------------------------------ Jun-12 3:19:25 PM Z-Wave Error Internal: Cannot open COM port /dev/ttyAMA0, exiting. Ex=Input/output error Jun-12 3:19:24 PM Z-Wave Warning Internal: Cannot configure COM port /dev/ttyAMA0, will attempt an open. Jun-12 3:19:24 PM Z-Wave Warning Internal: Exception(1) with COM port (/dev/ttyAMA0): Input/output error Jun-12 3:19:24 PM Z-Wave Internal: Getting node information from controller... Jun-12 3:19:24 PM Z-Wave Warning Internal: Exception(1) with COM port (/dev/ttyAMA0): Input/output error Jun-12 3:19:05 PM Z-Wave Security S2 Support Is Enabled Jun-12 3:19:05 PM Z-Wave Internal: ............................................................ .......... Jun-12 3:19:05 PM Z-Wave Internal: .............................. FINISHED .............................. Jun-12 3:19:05 PM Z-Wave Internal: ............................................................ .......... Jun-12 3:19:05 PM Z-Wave Internal is the SIS for the network. Jun-12 3:19:05 PM Z-Wave Internal There is a SUC/SIS in the network. Jun-12 3:19:05 PM Z-Wave Internal Controller is static lib. Jun-12 3:19:05 PM Z-Wave Internal Controller chip type is ZW050x. Jun-12 3:19:05 PM Z-Wave The interface's security support has been set. Jun-12 3:19:05 PM Z-Wave Internal: Found 1 Z-Wave nodes in interface node ID 1 (Internal) Jun-12 3:19:05 PM Z-Wave Internal: Z-Wave interface node ID: 1, Home ID: C1EFE781 Jun-12 3:19:05 PM Z-Wave Internal: Z-Wave Serial API version: 8 Jun-12 3:19:05 PM Z-Wave Internal: Z-Wave services for the SECURITY COMMAND CLASS were successfully started. Jun-12 3:19:05 PM Z-Wave Internal: Controller firmware version: 2.8 Jun-12 3:19:05 PM Z-Wave Internal: Controller Manufacturer: Express Controls, ID=0x2, Type=0x5 Jun-12 3:19:01 PM Z-Wave Internal: Getting node information from controller... Jun-12 3:19:01 PM Z-Wave Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect. Jun-12 3:18:59 PM Z-Wave Internal: Getting node information from controller... Jun-12 3:18:59 PM Z-Wave Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect. Jun-12 3:18:57 PM Z-Wave Internal: Getting node information from controller... Jun-12 3:18:57 PM Z-Wave Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect. Jun-12 3:18:45 PM Z-Wave Internal: Getting node information from controller... Jun-12 3:18:45 PM Z-Wave Internal: The Z-Wave API Execution Thread was Started or Restarted. Jun-12 3:18:45 PM Z-Wave Internal: The Z-Wave Command Execution Thread was Started or Restarted. Jun-12 3:18:45 PM Z-Wave Internal: ---------------------------------------------------------------------- Jun-12 3:18:45 PM Z-Wave Initializing Z-Wave interface Internal (Internal) on /dev/ttyAMA0 Jun-12 3:18:45 PM Z-Wave Internal: ---------------------------------------------------------------------- Jun-12 3:18:45 PM Z-Wave Internal: ============================================================ ========== Jun-12 2:48:18 PM Z-Wave Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
Thanks for the info.. I'll tell you that HomeSeer isn't making a fan out of me on this device.. First, they send it with the wrong firmware, then their download to "fix" their mistake has an error in it.. that they haven't bothered to fix since January? Yikes.
Do you know if can this be done remotely in a shell? or do I edit directly on the raspberry pi interface?
They were willing, but I didn't want to wait longer, these were already on backorder when I bought them.. My hours to resolve this add up to triple what I paid for the device. If they know they have a download with an error in it, why the hell wouldn't they just fix it. And sending a device with another device's programming on it is pretty sloppy.
Currently using my Zee S2 as a test unit to try HS4 for the PI. I reloaded the image fresh yesterday using this thread (https://forums.homeseer.com/forum/hs...-now-available).
Everything seemed ok but I was not able to get the internal zwave network to initialize, kept saying it was disabled. Tried all sorts of things, dozen restarts, nothing.
I stumbled across this thread describing the same issue. I then SSH'd into the Zee S2 and entered the lines one at a time and then restarted the unit. Zwave finally came up.
Code:sudo cp -p /boot/cmdline.txt /boot/cmdline.txt-orig echo "dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait bootmenutimeout=n" | sudo tee /boot/cmdline.txt
- 2 likes
