I could use some expert help on this one.
I am trying to understand the process to use to move my network from a failed S2 to a new S2 controller. I have a current backups from the failed unit with the ZW plugin disabled. I also have a backup with the ZWave plugin enabled. The restore with ZW plugin disabled, loads with the ZW off in new S2 As I understand, I do the following:
1. Remove power from the old Zee S2 to insure it is not active on the network.
2. Attach a Keyboard and Monitor to the new S2 and boot it up.
3. Install updates and plugins
4. Restore the current backup(with ZW Off) that came from the now failed S2 to the new S2.
5. When the new S2 reboots after the restore completes, do an "r' reset of the network settings at the bootup pause to move the new S2 to DHCP IP to avoid having both S2s ending up of the same IP address.
6. In the setup menu on the HS app, change the license information from that of the failed S2 to that of the new S2 controller
7. Verify that the device list and events are complete.
8. Enable the ZWave plugin.
At this point in the process, the questions take over. My questions are as follows:
1. Will the node info get loaded even with the ZW plugin disabled?
2. Will the new S2 be set as the primary controller on Node 1 or will it default to secondary controller status?
3. Is there any additional procedures that will need to be performed on the ZWave interface such as: Import and Scan, Full Scan, Re-include, etc.
4. Will battery powered nodes need special treatment? 17 of my 50 nodes are battery powered.
5. Will the node Association settings get linked to the new S2 controller?
This became an important issue for me recently when my S2 continued to run the ZW network but refused to be contacted using any of the several HS Tools. It was purchased in early 2016. The backup from the now failed S2 loaded into the new S2 but all the IF statements were missing from the events and would not allow editing of the events. I concluded that all of the several backups I had were probably corrupted and had to completely manually rebuild all 50 nodes and reprogram all 188 events to get my automation back which was not fun. The factory reset that HS support recommended I do on the old S2, bricked the unit. It would perform the factory reset but displayed errors on some of the file loads during the boot. It would boot up Linux but not start the HS app. Not being the type to give up, I re-flashed(several times) the SD card, and also replaced the card. After the re-flash, it boots up once and bricks when rebooted. The re-flash actions also deleted the factory reset capability that was in the original Linux load. My conclusion is that either the unit takes a Linux version no longer available or it has suffered a failure most likely related to the network interface area. It shows up as on-line in the router IP list but refuses all contact. I would greatly appreciate comments on my questions - Thanks.
