Speak action seems to block subsequent actions
    This is a very recent issue.
    I noticed this morning that my event to water all the lawns executed as far as the initial Speak command to advise that watering will begin, but then none of the 5 following actions to the sprinkler were being executed.
    I turned on the sprinkler from the device page, no problem.
    then I commented-out the Speak instruction, manually ran the event and the watering is happening as expected.
    Has anyone else noticed anything unusual like this?
    I noticed it on another event last night, on the garage door - I wouldn't receive the email indicating the garage door was shut because it followed the Speak command. But once I changed the order, it worked fine.
    Once my watering routine completes, I will reboot the Zee and re-test to see if that makes a difference.
    Current Date/Time: 7/31/2019 8:49:19 AM
    HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.534
    Linux version: Linux HomeTrollerZeeS2V5 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux System Uptime: 1 Day 21 Hours 12 Minutes 12 Seconds
    IP Address: 192.168.15.10
    Number of Devices: 217
    Number of Events: 148
    Available Threads: 320
    HSTouch Enabled: True
    Event Threads: 5
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    Enabled Plug-Ins
    3.0.0.5: CM15A
    3.0.0.65: EasyTrigger
    3.0.0.18: EnvCan
    3.0.1.252: Z-Wave
    Update - a soft restart didn't work but a cold re-boot seemed to fix things.
