Hey Folks, I have a USB speaker connected to my Zee-S2. When I login as "homeseer" on the Zee terminal and run "aplay /usr/local/HomeSeer/Media/chime.wav", I hear the audio file just fine and it sounds great. But if I create an HS3 event that launches the action "Plan an audio file" and I set it to play /usr/local/HomeSeer/Media/chime.wav", I don't hear anything. I even modified the event to run "/usr/local/bin/aplay /usr/local/HomeSeer/Media/chime.wav" and still nothing can be heard. No errors show up in the log file when launching the event.
When I go into Linux Tools and try running aplay from the "Execute a Linux command", I still hear nothing. If I do a "whoami" from the "Execute a Linux command" box, I see "root". Is there a problem with "root" running aplay versus "homeseer" running aplay? What else could be going on here? I also tried all of the above using the "play_audio.sh" script in the /usr/local/HomeSeer/ directory and got the same results. Thanks in advance!
Current Date/Time: 9/30/2019 10:03:31 PM
HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.548
Linux version: Linux HomeTrollerZeeS2V6 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux System Uptime: 0 Days 1 Hour 10 Minutes 51 Seconds
IP Address: 192.168.1.67
Number of Devices: 4
Number of Events: 1
Available Threads: 399
HSTouch Enabled: False
Event Threads: 2
Event Trigger Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Enabled Plug-Ins
3.0.1.252: Z-Wave
Number of Events: 1
Event Threads: 2
Email Send Queue: 0
Enabled Plug-Ins
3.0.1.252: Z-Wave
