UPNP Discovery is not running
    After a power failure, I restarted my HomeSeer. Noticed that the logs are repeatedly being flooded by the messages below.
    Nov-12 8:57:56 PM Warning If this system is not on a network, disable UPNP in Setup. If HS2 is also running, disable UPNP on that system.
    Nov-12 8:57:56 PM Warning UPNP Discovery is not running, most likely your PC does not have a valid IP address, will try to enable later: Invalid arguments
    Nov-12 8:57:25 PM Warning If this system is not on a network, disable UPNP in Setup. If HS2 is also running, disable UPNP on that system.
    Nov-12 8:57:25 PM Warning UPNP Discovery is not running, most likely your PC does not have a valid IP address, will try to enable later: Invalid arguments
    Going in the setup, I noticed that my WIFI SSID was outdated and gave the new name and passcode. Despite restart it continues to give these messages. The systems work although a little bit slow.
    I can see my HometrollerZee is connected both wireless and cabled to my network and has got an IP address.
    I am runnin HS3 ZEE S2 Edition 3.0.0.368 with Imperihome plugin
    What to do?
    Careful with UPNP! Read this first : https://www.varonis.com/blog/what-is-upnp/
    Eman.
      But I have not (at least to my knowlegde) asked for UPNP. So how do I get rid of it?
        Go to Tools Tab>Set-up>Network Tab
        Go down to Web Server Settings
        It is an option box that is clickable to turn it on or off
        **This is on Windows. No idea if same on Linux systems.
          It is the same on Linux.
            Thanks it worked. How it suddenly came out of the blue is strange
