I added a DHCP reservation for my HomeTroller Zee, did a reboot through the GUI and the web interface is no longer responding. I am able to ping the IP and log in ssh using the homeseer login. The Maintenance page (port 911) loads but using option #1 (reset) and option #2 (reinstall) does not resolve the problem. I removed the reservation and reloaded. Same issue.. I don't see anything odd on the boot log:
root@HomeTrollerZeeS2V7:/var/log# tail boot.log
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Started Lighttpd Daemon.
Setting audio output to analog...
numid=3,iface=MIXER,name='PCM Playback Route'
; type=INTEGER,access=rw------,values=1,min=0,max=2,step=0
: values=1
HomeSeer is starting...
[ OK ] Started /etc/rc.local Compatibility.
Starting Hold until boot process finishes up...
Starting Terminate Plymouth Boot Screen...
root@HomeTrollerZeeS2V7:/var/log# cat boot.log
[ OK ] Mounted /var/log.
[ OK ] Mounted /tmp.
[ OK ] Started Load/Save Random Seed.
[ OK ] Reached target Sound Card.
[ OK ] Started Show Plymouth Boot Screen.
[ OK ] Reached target Paths.
[ OK ] Created slice system-systemd\x2drfkill.slice.
Starting Load/Save RF Kill Switch Status of rfkill0...
[ OK ] Found device /dev/mmcblk0p6.
Starting File System Check on /dev/mmcblk0p6...
[ OK ] Started Load/Save RF Kill Switch Status of rfkill0.
[ OK ] Created slice system-ifup.slice.
[ 4.455130] systemd-fsck[291]: fsck.fat 3.0.27 (2014-11-12)
[ 4.456837] systemd-fsck[291]: /dev/mmcblk0p6: 146 files, 42839/120956 clusters
[ OK ] Started File System Check on /dev/mmcblk0p6.
Mounting /boot...
[ OK ] Mounted /boot.
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
Starting Tell Plymouth To Write Out Runtime Data...
Starting LSB: Raise network interfaces....
[ OK ] Reached target Remote File Systems.
Starting Trigger Flushing of Journal to Persistent Storage...
Starting LSB: Prepare console...
Starting LSB: Switch to ondemand cpu governor (unles... is pressed)...
[ OK ] Started Tell Plymouth To Write Out Runtime Data.
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Started Trigger Flushing of Journal to Persistent Storage.
[ OK ] Started LSB: Switch to ondemand cpu governor (unless...ey is pressed).
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started LSB: Prepare console.
Starting LSB: Set console font and keymap...
[ OK ] Started LSB: Raise network interfaces..
Starting ifup for wlan0...
[ OK ] Started ifup for wlan0.
[ OK ] Started LSB: Set console font and keymap.
[ OK ] Reached target System Initialization.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Timers.
Starting Restore Sound Card State...
[ OK ] Reached target Basic System.
Starting LSB: Autogenerate and use a swap file...
Starting LSB: triggerhappy hotkey daemon...
Starting System Logging Service...
Starting Avahi mDNS/DNS-SD Stack...
Starting Regular background program processing daemon...
[ OK ] Started Regular background program processing daemon.
Starting Enable support for additional executable binary formats...
Starting dhcpcd on all interfaces...
Starting D-Bus System Message Bus...
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
Starting Login Service...
[ OK ] Started System Logging Service.
[ OK ] Started Restore Sound Card State.
[ OK ] Started LSB: Autogenerate and use a swap file.
[ OK ] Started LSB: triggerhappy hotkey daemon.
[ OK ] Started dhcpcd on all interfaces.
Mounting Arbitrary Executable File Formats File System...
[ OK ] Reached target Network.
[ OK ] Reached target Network is Online.
Starting LSB: Start NTP daemon...
Starting LSB: Apache2 web server...
Starting OpenBSD Secure Shell server...
Starting Lighttpd Daemon...
Starting /etc/rc.local Compatibility...
Starting Permit User Sessions...
[ OK ] Mounted Arbitrary Executable File Formats File System.
[ OK ] Started Login Service.
[ OK ] Started LSB: Apache2 web server.
[ OK ] Started Permit User Sessions.
[ OK ] Started Enable support for additional executable binary formats.
[ OK ] Started LSB: Start NTP daemon.
Enter r then press ENTER within 10 seconds to reset the network settings
ERR 2:
Unable to open `/dev/input/event0'
No such file or directory
Network settings not changed
: values=1
: values=1
Mounting /boot...
ERR 2:
: values=1
