Startup error
    Startup error
    I just noticed that I am getting this error in my HS log at startup.
    Jun-01 15:04:25 Error Compiling script Startup.vb: Error running vbnc: Cannot find the specified file
    Is that something I need to investigate or be concerned about?
    Malcolm
    With that error, you will not be able to run any scripts. Looks like a repair of mono is required.
    Jon
      I think it means the Startup.vb file is missing - I could be wrong though...
      68 Z-Wave Nodes, 175 Events, 359 Devices
        I went through a mono re-install using this https://helpdesk.homeseer.com/articl...date-to-mono-5 and confirmed it was successful.
        Unfortunately, I'm still getting the start up message.
        Malcolm
          Is this the file?
Name:	Annotation 2020-06-01 174306.png
          Malcolm
            I don't believe I have ever edited this so it must be "as installed"?
            Malcolm
              Verify vbnc package is properly installed:
              dpkg -V mono-vbnc
              This only outputs problems. No output indicates all good.
                from the prompt, just type vbnc you should get some compiler response
                  dpkg -V mono-vbnc
                  it returns
                  homeseer@HomeTrollerZeeS2V2:~ $ dpkg -V mono-vbnc
                  dpkg: package 'mono-vbnc' is not installed
                  Malcolm
                    Originally posted by MalcolmS View Post
                    it returns
                    Well there you have it - that's required.
                    sudo apt-get -y install mono-vbnc
                      perfect, thank you
                      Malcolm
