Zee S2, HS4, which board to enable Z-Wave interface?
    Good evening,
    To enable the Z-Wave daughter board which interface should I select?
    Thank you
    HS4 ZEE S2 Edition 4.0.7.0 (Linux)
    ~Bill
    Internal
      Thanks ZWolf. I had tried that - you confirmed my suspicions there is a further issue.
      I haven't pulled it apart - hopefully it is a loose card.
      ~Bill
        There are a couple of boot parameters that need some TLC and HST can't seem to find in their hearts to apply it...
        In the file /boot/config.txt, if you don't see this line, add to the end
        # disable bluetooth function and restore serial0/ttyAMA0 over GPIO 14&15
        dtoverlay=pi3-disable-bt
        In the file /boot/cmdline.txt, if the clause in red is present, edit the file to remove it.
        dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 ...
        Then reboot.
          Sigh. Thanks for the info. They are making me learn some Linux at work. Now I'm being attacked from home also. Seriously appreciate your expertise.
          ~Bill
            @zwolfpack You nailed it - THANK YOU!!!!!!!
            The config.txt was fine but the cmdline.txt needed the console=serial0,115200 portion removed.
            Came right up after reboot.
            ~Bill
