My Hometroller Zee S2 after power failure, unit power ON won't boot I installed a screen and a keyboard and on the linux listing the last line is "end Kernel panic - not syncing: no working init found ...." I tried to do a "recovery to HS4" without success, stop at 50% and do the same for HS3 and stop at 20%. Is the problem on the SD memory card? Can we copy the last backup file? this is not the first time that I have had an electrical failure and I have never had a problem. Thank you for the support
HomeTroller Zee S2 won't restart
Before doing anything try reading this first : https://www.raspberrypi.org/forums/v...p?f=28&t=58151- If you like using Raspberry PI's consider something like this : Geekworm NASPi 2.5 inch SATA HDD/SSD NAS Storage Kit for Raspberry Pi 4 Model B especially when your device in no longer under warranty (this assumes that you had a backup to rebuild your system)
Eman.
Thanks Eman for answering me! When I plug in my Hometroller Zee S2 the red led turns on and the green led turns on and off quickly on the motherboard only once. like many i didn't think i should make a copy of the sd card. now I know after reading on the forum about SD card topics. I applied for a new card and after that I will make a copy for the future. I've also read that every time you make changes to HS4 it automatically backs up itself, is that true? or I have to do a manual backup! .Thank you
Maybe zwolfpack can lend a hand a troubleshoot this...
About backups : https://docs.homeseer.com/pages/view...ageId=17466488
Eman.TinkerLand : Life's Choices,"No One Size Fits All"
