Can I use HSTouch with a hometroller pi?
HSTouch with HomeTroller Pi?
Should work. I am using HSTouch client on local Embedded Wintel boxes with Homeseer 3 running on Ubuntu Linux and it works fine for me.
Just looked at my HS3 / tools / setup / network and see the HSTouch clients showing up as "Connected speaker clients".- Pete
Auto matorHomeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb
HS4 Pro - Ubuntu 22.04 / Lenova Tiny M900 / 32Gb Ram
HSTouch on Intel tabletop tablets (Jogglers) - Asus AIO - Windows 11X10, UPB, Zigbee, ZWave and Wifi MQTT automation-Tasmota-Espurna. OmniPro 2, Russound zoned audio, Alexa, Cheaper RFID, W800 and Home Assistant
- Likes 1
I suppose the HSTouch server is baked into the HS4 software and not really a plugin.
yes.
Here utilize mini Atom based tabletop Gb or WLAN connected 8" tablets (no batteries) for run HSTouch in embedded Windows. Hardware customized with Seabios, SSD drive and RTC (built in WLAN / BT stick). I also run SAPI voice fonts and speaker.exe on same said tabletops. (~10 years now)
With EFI bios will run Android (for Intel) and Ubuntu Linux.
Also testing HP Elitepad G2 1000's Windows 11 running HS Touch and an Asus V161 very thin touchscreen computer. They do well.- Pete
