Hi,
I recently bought a Hometroller Zee, and I'm switching back from Fibaro HC2 to Homeseer on a Fit-pc with HS3 Pro (still had a license). I would like to know if there is a way to combine my HS3 Pro (with all the right plugins) with the Hometroller Zee.
On my previous (HS2) system I had some problems with remote devices, bad reception on some nodes. I tried Fibaro HC2, the problems are far worse, lot of dead nodes after updates, and some dead nodes for no apparent reason (and bad logging so no way to find out what was wrong).
I can of course setup a separate Zee network, and control stuff with http commands from my HS3 Pro system, but I also remember it is possible to combine the HS3 Pro with a Zee. Can't seem to find it again, please advise.
Thanks!!!
E
Thanks!!!
E
