Zee S1 and S2 image release notes
This is a sticky topic.
    Release 3.0.0.182 (Zee S2 only)
    * Fixed CM15A plugin now runs properly
    * Fixed playing audio files to speaker clients
    Release 3.0.0.181
    * See HS3 release notes for details on changes
    http://forums.homeseer.com/showthread.php?t=174927
    well, I cannot say it does run properly. The plug-ins are installed ok but in the log file the message "Unable to communicate with CM15A, try re-connecting to USB port, will retry in 5 seconds...: Connection refused" keeps repeating.
    I run HS 3.0.0.208 on a RaspberryPI 2B with the Raspbian Jessie image. I installed everything following the thread http://board.homeseer.com/showthread...spberry&page=5 by JohnD and Pete. Exept for the first 5 points, because I did not use the image of
    rmasonjr.
    some info:
    Current Date/Time: 12/16/2015 3:45:11 PM
    HomeSeer Version: HS3 Pro Edition 3.0.0.208
    Linux version: Linux RPiZwave 4.1.13-v7+ #826 SMP PREEMPT Fri Nov 13 20:19:03 GMT 2015 armv7l GNU/Linux System Uptime: 0 Days 1 Hour 17 Minutes 8 Seconds
    IP Address: 192.168.2.82
    Number of Devices: 1
    Number of Events: 1
    License: Trial
    License: 0
    User Name and Access Level: cor (Admin)
    WAN IP Address: 94.231.247.11
    Web Server Port: 80
    Location: (Latitude) 52.35 (Longitude) -4.87 City/State-Netherlands,Amsterdam,-4.87,52.35
    Enabled Plug-Ins
    3.0.0.4: CM15A
    3.0.0.68: HSTouch Server
    3.0.1.25: Z-Wave
    Can someone give me a clue of where to find a solution for this?
    Cor
      Download... (only for pi2)
      Wouldn't hurt to mention that the current process to re-image begins at http://homeseer.com/current-downloads.html, where you can click on a link which will download hs3pi2boot.zip. When expanded the instructions will tell you how to reformat the SD card and the copy the contents of the zip file to the SD. Booting the Zee with the SD, presuming you have an HDMI monitor and a USB keyboard connected (and an Internet connection), will eventually start a download of the real image. (Note: this seems to occur at something between 14-20kb/hour -- it take a long time.)
        Unable to update Zee S2
        Tried to update the Zee S2 from 3.0.0.297 to 3.0.0.318 from the Setup page of the web interface by clicking "Install Version 3.0.0.318" and I get "Error downloading update file (http://www.homeseer.com/updates3/hslinux_zees2_3_0_0_318.tar.gz:ERROR:error:NameResolutionFai lure"
        Any idea what's going on?
          Originally posted by meboxster View Post
          Tried to update the Zee S2 from 3.0.0.297 to 3.0.0.318 from the Setup page of the web interface by clicking "Install Version 3.0.0.318" and I get "Error downloading update file (https://www.homeseer.com/updates3/hslinux_zees2_3_0_0_318.tar.gz:ERROR:error:NameResolutionFai lure"
          Looks like their site is down as of this time...
          68 Z-Wave Nodes, 175 Events, 359 Devices
            Yes, DNS problem, its fixed now and the update should download.
              Latest production version of HS3 for the ZeeS2V2
              Hi - I wanted to verify the latest production version of HS3 for the ZeeS2V2. Is the latest version .318 (as of 8/10/2017)? If yes, is there a target date for the next HS3 release for the ZeeS2V2?
              Thanks!
              Mike
                We are doing some final testing on build 3.0.0.350 and hope to release it soon.
                The Beta is available so you could load it if you want.
                Thanks!
                Mike
                  OK - Excellent - Thank you for the update. I just wanted to make sure that I was not out of sync with the latest production version for the ZeeS2V2. I will keep a look out for the next official ZeeS2V2 release. Thanks again!
