How To use Google voice for text-to-speech on Zee and Linux
This is a sticky topic.
    Note: This no longer works, read down to find an alternate solution
    The following applies to the HomeTroller Zee (S1 or S2) the SEL, or Linux HS3.
    This procedure assumes that you know how to SSH to your controller and access the command prompt.
    The TTS on Linux is not very good, but there is a way to have your text converted to speech using Google. The TTS is converted using a script called speak_to_file.sh in the HS folder (/usr/local/HomeSeer)
    The result is the text will be spoken with the same voice that used on Android.
    This requires the mpg123 medial player, so install that first with the command:
    sudo apt-get install mpg123
    Replace that file contents this:
    #!/bin/bash
    # Speech Script by Dan Fountain #
    #      TalkToDanF@gmail.com     #
    INPUT=$2
    STRINGNUM=0
    ary=($INPUT)
    echo "---------------------------"
    echo "Speech Script by Dan Fountain"
    echo "TalkToDanF@gmail.com"
    for key in "${!ary[@]}"
      do
        SHORTTMP[$STRINGNUM]="${SHORTTMP[$STRINGNUM]} ${ary[$key]}"
        LENGTH=$(echo ${#SHORTTMP[$STRINGNUM]})
        #echo "word:$key, ${ary[$key]}"
        #echo "adding to: $STRINGNUM"
        if [[ "$LENGTH" -lt "100" ]]; then
          #echo starting new line
          SHORT[$STRINGNUM]=${SHORTTMP[$STRINGNUM]}
        else
          STRINGNUM=$(($STRINGNUM+1))
          SHORTTMP[$STRINGNUM]="${ary[$key]}"
          SHORT[$STRINGNUM]="${ary[$key]}"
        fi
    done
    for key in "${!SHORT[@]}"
      do
        #echo "line: $key is: ${SHORT[$key]}"
        echo "Playing line: $(($key+1)) of $(($STRINGNUM+1))"
        NEXTURL=$(echo ${SHORT[$key]} | xxd -plain | tr -d '\n' | sed 's/\(..\)/%\1/g')
        mpg123 -w $1 -q "http://translate.google.com/translate_tts?tl=en&q=$NEXTURL"
    done
    The above script was modified from this one:
    http://danfountain.com/2013/03/raspb...ext-to-speech/
    I'm getting:
    -bash: mpg123: command not found
    This is on HS3 Linux on a Rpi2.
    What packages are required for mpg123?
    68 Z-Wave Nodes, 175 Events, 359 Devices
      Install mpg123 with:
      Originally posted by rmasonjr View Post
      I'm getting:
        oh wow! Rich, that sounds so much better than the original voice! Many thanks!
          does this hack still work for anyone?
          I'm getting "HTTP request failed: 503 Service Unavailable", and if I paste the google url in a browser I first get a captcha.
            Mine was working last night - I get TTS on outside motion. I'll test it tonight and see...
              Right, looks like they added a captcha to the page, so I guess this won't work anymore. If you enter the text, it does start working without a prompt, but I'm not sure if its verifying the IP, or maybe there is a timeout, so it may not work for very long.
                Thats a shame. The quality of the Google TTS was very good
                  Alternate script for text-to-speech
                  A user has modified the script to use voice RSS, pretty good voices.
                  You will need your own API key for this to work, and edit the script by inserting your key into the second to last line.
                  #!/bin/bash
                  INPUT=$2
                  STRINGNUM=0
                  ary=($INPUT)
                    do
                      else
                      fi
                  done
                    do
                  	mpg123 -w $1 -q "http://api.voicerss.org/?key=Your_API_Key&f=48khz_8bit_stereo&hl=en-gb&src=$NEXTURL"
                  done
                    Sounds pretty good - see attached...
