How To Display 24 Hour Time in HomeTroller Zee
This is a sticky topic.
    On the Zee, Zee S2, and SEL, you can make a change so HS3 displays times in 24 hour format.
    To ensure that HS uses the 24 hr time format:
    1. SSH to your unit, log in, then go to the HS folder with:
    2. cd /usr/local/HomeSeer
    3. Now edit the autostart_hs file, the file contains the locale that the unit will run under, the first line is:
    4. export LANG=en_US.UTF-8
    5. Change this line to the locale you want to use, 24 HR time will be displayed if you set it to:
    6. export LANG=en_GB.UTF-8
    7. You can edit the file with the command:
    8. sudo nano autostart_hs
    9. After making the change, type CONTROL X to save and exit.
    10. Reboot the unit and HS will now display times in 24 hr format.
    Note, on the Zee and Zee S2 you may need to generate the locale you want to use (GB is already there). Run the following command to enter a tool where you can generate new locales:
    sudo raspi-config
    Select the "Internationalisation" option to select the locale you want to generate.
    Perfect! Thank you!
