This may be the wrong place to ask this question, but how do I know if a particular plugin is supported in the Linux versions of homeseer?
Plugin support
If you are from within HS then it will only show plugins in the updater that are suitable for your setup, so if they are there they should work.
If you want to search from the list here http://www.homeseer.com/homeseer-plug-ins.html then it should show anything with a double asterisk as being linux compatible.
If you are using plugins that do not appear in the updater then you are reliant on whether or not the thread/documentation says so.
Do you have one in mind?
Originally posted by mrhappy View PostIf you are from within HS then it will only show plugins in the updater that are suitable for your setup, so if they are there they should work.
