Zwave Device "Unknown" Status
  • Zwave Device "Unknown" Status
    When a zwave deice goes into unknown status I clicked on the Advanced tab to look at the status value and it either says On or Off with a value of either 0, 100 or 255. How does HS know the device is unknown and what is the value of this device? Why does it stay on or off in the advanced tab?
    Thank you
    It is a flag (DeviceInvalidValue) in the device that is not shown. It can be cleared with
    &hs.DeviceInvalidValue(xxxx) = False
    where xxxx is the RefID of the device showing Unknown.
    Randy Prade
    Aurora, CO
    Prades.net
      I get unknown when a device can't be reached. Usually a plugin device and the socket has been switched off.
        Can an event be triggered if the flag becomes True?
        Michael
        HS3 Pro 3.0.0.470 | 849 devices | 349 events | OpenSprinkler | BLShutdown | EasyTrigger | NetCAM | Harmony Hub | Sonos | SDJ-Health | BLUPS | PHLocation | BLBackup | BLLock | Z-Wave 3.0.1.243 | weatherXML | Pushover 3P | Blue-Iris | AirPlaySpeak
          There are no event triggers that would see that flag. It might be possible to run a script on a recurring trigger.
          EDIT: There is a trigger for "An Invalid or Error State" for Z-Wave devices. This may work.
          Randy Prade
          Aurora, CO
          Prades.net
            I've never used this, but your comment made me recall there is a trigger for "changes and becomes an INVALID/ERROR state." I have a Z-Wave door lock that has issues on a frustratingly frequent basis and ends up showing "Unknown", so I'm going to try this...
              I forgot that was there. It is only on Z-Wave devices, so it should work. If I remember correctly, I tried to use it 3 or 4 years ago when I had a Z-Wave switch module in the garage that was going to Unknown status and it never triggered.
              Let us know if it works for you.
              Randy Prade
              Aurora, CO
              Prades.net
                I have tried the event trigger "An Invalid or Error State", but for me it does not work. It does not trigger when the device changes to status unknown. Would be good if it did, you can send a notification so you know there is a problem...
