Log in Raspberry Pi
  • Log in Raspberry Pi
    I downloaded the software got everything installed on microdisk goes thru boot up but can't get past login and password.
    I'm using the license id and the password emailed mt's not working.
    Once you install the software your key in find.homeseer.com to connect to HS3.
    -Rupp
      Can't find it on find.homeseer.com
        Are you trying to install the HS3-Pi or the HS3 Linux build? Are you referring to the console login prompt? If so, you don't need to login there -- not much can be done there to begin with.
        If you've loaded HS3-Pi and it installed & boots successfully, and the Raspberry Pi has an internet-reachable Ethernet connection, it should be able to be found by a search on https://find.homeseer.com. If not, detail what you have done so far.
