hello, i live in brazil.
I have an equipment that emits infrared signals much like the global cache. I've tried using the global cache plugin, but it does not recognize the device in the plugin. This equipment is called 7PORT works very well and cheaper. I would like to know how I send the string with the infrared code through the tcp network. Could you help me create a script? I do not have much experience. the device has 7 infrared ports, receives signals from the tcp network and sends to those ports p2 in the equipment. I do not understand much of structure. I did not find any commands or examples in the homeseer manual. I asked for support for them and it does not have a plugin for homeseer. I would like to use buttons in the hstouch application to send these infrared commands to the device.
I put an attachment with more detailed information of the code and the equipment
Thank you in advance.
