Contacting HomeSeer This Week
See more
See less
Struggling with Homeseer andUbuntu...
  • Struggling with Homeseer andUbuntu...
    Strugglin with getting Homeseer to work on Ubuntu Server 18.04
    This is my code from starting up:
    But no respons when I try http://10.0.0.56...
    wide@homeserver:/usr/local/HomeSeer$ sudo ./go &
    [1] 1645
    wide@homeserver:/usr/local/HomeSeer$ HomeSeer Linux starting...
    03:50:01:4867:[Database]->Opening (Mode=Read Only) up HomeSeer LOG database /usr/local/HomeSeer/Logs/HomeSeerLog.hsd
    03:50:01:6051:[Startup]->Loading Settings
    03:50:01:6192:[Warning]->HomeSeer was not shut down successfully the previous time it was started.
    03:50:01:7541:[Startup]->Settings Loaded.
    03:50:02:1834:[Startup]->
    03:50:02:1836:[Startup]->********************************************************************************
    03:50:02:1842:[Startup]->            HomeSeer version 3.0.0.435 Edition: HS3 Pro Starting Now
    03:50:02:1844:[Startup]->********************************************************************************
    03:50:02:1845:[Startup]->
    03:50:02:3051:[Startup]->Creating Class Objects...
    03:50:02:3099:[Startup]->COM port classes started.
    03:50:02:3195:[Startup]->Application interface class started.
    03:50:02:3529:[Startup]->Web server class started.
    03:50:02:3536:[Startup]->E-Mail SEND class started.
    03:50:02:3539:[Startup]->E-Mail RECEIVE class started.
    03:50:02:3554:[Startup]->Plug-In Interface class started.
    03:50:02:3562:[Startup]->Local voice recognition class started.
    03:50:02:3574:[Startup]->Database SAVE process started.
    03:50:02:3576:[Startup]->Loading configuration file ...
    03:50:02:3918:[Database]->Opening (Mode=Read Only) up HomeSeer database /usr/local/HomeSeer/Data/HomeSeerData.hsd
    03:50:02:4495:[Warning]->Configuration database has no devices in it: /usr/local/HomeSeer/Data/HomeSeerData.hsd
    03:50:02:4512:[Database]->Loading Devices...
    03:50:02:4518:[Load Config]->0 total devices loaded.
    03:50:02:4589:[Load Config]->Loading Event Groups...
    03:50:02:4645:[Load Config]->Loading Events...
    03:50:02:4660:[Load Config]->0 total events loaded.
    03:50:02:4661:[Load Config]->Loading COUNTERS...
    03:50:02:4686:[Load Config]->Loading TIMERS...
    03:50:02:4735:[Startup]->HomeSeer version is: 3.0.0.435
    03:50:02:4738:[Startup]->Creating Speaker Client Interface Object...
    03:50:02:4752:[Warning]->This version of HomeSeer is not registered and is currently disabled
    03:50:02:4893:[Info]->Remote plug-in API interface started on port 10400
    03:50:02:4895:[Startup]->Checking for available plug-ins
    03:50:02:4943:[Startup]->Initializing Plug-Ins
    03:50:02:5184:[HSTouch Server]->Server started on port 10200
    03:50:02:5201:[Startup]->HStouch server started, waiting for clients to connect.
    03:50:02:5413:[Web Server]->Local IP address is: 10.0.0.56
    03:50:02:5437:[Web Server]->Web Server started on port 80
    03:50:02:6533:[Startup]->Start automation engine...
    03:50:02:6594:[Startup]->Initializing Speaker Client Interface
    03:50:02:6690:[Speech]->Listening for remote speaker connections on port 10401
    03:50:02:7030:[Database]->Opening (Mode=Read/Write) up HomeSeer Energy database /usr/local/HomeSeer/Data/Energy/Energy.hsd
    03:50:02:9177:[Startup]->Updater services starting...
    03:50:02:9219:[Startup]->Starting Find service...
    03:50:02:9280:[Startup]->Starting Event Scheduler...
    03:50:02:9306:[Startup]->HSSentry is disabled in Setup, sentry will not be started.
    03:50:02:9316:[Startup]->Start up complete.
    Mono is installed:
    Mono JIT compiler version 5.16.0.179 (tarball Thu Oct  4 10:20:38 UTC 2018)
        TLS:           __thread
        SIGSEGV:       altstack
        Notifications: epoll
        Architecture:  amd64
        Disabled:      none
        Misc:          softdebug
        Interpreter:   yes
        LLVM:          yes(3.6.0svn-mono-/)
        GC:            sgen (concurrent by default)
      Ohh, found it, need to register...
